GOL ELECTRICAL PROBLEMS
14 years 9 months before #15869 by manual-mecanica
GOL ELECTRIC PROBLEM PUBLISHED BY MANUAL-MECANICA
I would like to know if someone can help me because I have a problem on the board, in the alternator light it does not turn on when I start, but the alternator works well load 13.50 volt The board does not mark me anything, the lamp works on the board, sorry the car is a mod 1999 goal with electronic ignition thanks for the help you can give me
14 years 9 months before #15871 by manual-mecanica
Manual-Mecanica Response on the Re: Gol Electric Problems
Hello friend, I tell you that I am an electrician and I will tell you that it may be that you burn the lamp or that the cable that comes from the treasurer to the lamara is cut off or that that cable from which the treasurer leaves is broken so I recommend that you start to check the lamp that is the most common of burning
14 years 9 months before #15888 by manual-mecanica
Thank you for the help friend, all that is communicate, I review it, the lamp has tension, which I do not know how to work on the lamp, I am an electronic technician if you can give me an idea of ​​how the lamp works, as I turn on
