MIA AUTO BURN OIL
14 years 9 months before #15874 by manual-mecanica
Mia Auto Burns Oil Published by Manual-Mecanica
Hello mechanical friends and fans as I here I leave a problena that I have with my car is low of hoops and is burning oil nesec. Know if the inside they sell to thicken the oil if it works in Realida and if it is so if they can explain it a little already from now on thank you
14 years 9 months before #15899 by manual-mecanica
Manual-Mecanica Answer on the Re: Mia Auto Burning Oil
Hello friend, if your car has many km and burns a lot of oil, I do not think that solutions with additives, you are very likely to have to change hoops and check the wear of the valve guides and their challenges, greetings. :)
14 years 9 months before #15904 by manual-mecanica
Motors with hydraulic taes are not advisable to place these additives since they increase the viscosity of the oil and the taes are not fully loaded.
14 years 9 months before #15915 by manual-mecanica
Aver answering your question if they work but they only work for a relatively short period of time no more than a week and less up to 4 days and now, how it works it is simple is an additive to vase of oil very thick that the mescad with which you already have its viscosity until you achieve a uniform, swelling what you had originally when making the oil more will not go so easy for the ex -semic problem.
14 years 9 months before #15930 by manual-mecanica
I am sorry but I have to disarm the motor shakes with the cylinder cover and repair it completely continues with the rings Control controls the light of the pistons may have to rectify a greeting.
