Nissan Cabstar
14 years 9 months before #15933 by manual-mecanica
Nissan Cabstar published by Manual-Mecanica
The brake pedal is very hard that can be thanks
14 years 9 months before #15934 by manual-mecanica
Manual-Mecanica Response on the Re: Nissan Cabstar
Hello, with respect to your question, it may be that brake servo is not working as appropriate. The way to try this is to start the car with the tight brake pedal, if when it starts, the pedal goes down and gets soft, it means that it works well. Otherwise the problem is the servo. This can be repaired, it is not necessary to put it new.
A hug and luckB)
14 years 9 months before #16003 by manual-mecanica
The hard pedal is the fault of the Servofreno there is no more.
14 years 9 months before #16155 by manual-mecanica
Thank you, I will try it, I wanted to be sure before demolishing anything
14 years 9 months before #16164 by manual-mecanica
I am in the agency and what I have seen that the bite are glued nunka I have changed the servo
