Generally when the regulatory boxes change this problem appears if you say that everything is fine and that the alternator is well, Czech that you do not need to connect any cable and the other that are well connected, that is, in the terminal that corresponds to this of the box, if it is with a Czech alternator the board and the tracks of the same, it is that green paper with copper lines that is in the tracera of the board.
