Renault 21 problem
14 years 9 months before - 14 years 9 months before #15961 by manual-mecanica
Problem with Renault 21 posted by Manual-Mecanica
Hello I have problems with a Renault 21 Full Injaction Motor 2.3 is passing water for the water, it has strength, it does not present any other fault only that, the bed of the camera is new. I would like your help in this regard. Thank you
Last edition: 14 years 9 months before by . Reason: Inverti the fault is not water for oil is water for water
14 years 9 months before #16006 by manual-mecanica
Manual-Mecanica Answer on the re: Problem with Renault 21
There are several options, the first is that this bad place is the assault of the cylinder head or lack of squeeze or that it is crooked or tristed if it is not rectified. The second is that if you have oil filter with heat exchanger then you can make a bridge between the hoses to eliminate the theme and see what happens.
14 years 9 months before #16014 by manual-mecanica
Ok thanks I will try your suggestion anything I write to you again
