problems with check Engine
14 years 9 months before #15964 by manual-mecanica
Problems with check Engine published by Manual-Mecanica
Hello to everything, well my consultation is the following; I have a mitsubishi eclipse year 1995 Motor 2.0 gs without a mechanical turbo and since a while ago I have a state giving a problem only on the road and highways, the problem is the follow, after the 130 kilometer per hour I turn on the check Engine but the car is without any problem the pirmra you see k In perfect condition, I don't know how alone the check lights me ??? In Ciudad it is perfectly well, several people have told me that it can be a problem with the oxygen sensor but nobody has given me the security of K outside that exactly, I hope they help me with me problem thanks.
14 years 9 months before #15972 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Check Engine
The most ideal is to shine it to see if you have any code taxed in your memory, since several sensors can cause you an intermittent failure.
14 years 9 months before #16011 by manual-mecanica
It is true the most economical solution is to scan it and then see that sensor is therefore this failure can be from the TP of the temperature sensor, oxygen evaporation of gases and a lot more, scan it and comment.
