Problems with Hyundai Sonata gearbox
14 years 9 months before #15995 by manual-mecanica
Problems with Hyundai Sonata gearbox published by Manual-Mecanica
I cannot take the gearbox from an Hyundai Sonata year 2002 dohc 16v I make it lever and the engine box is separated but it is returned, it is as if it were caught inside, as if a march was getting, but I turn the Sigual U do not turn the outputs of the sticks I do not know what to do what to do
14 years 9 months before #16018 by manual-mecanica
Manual-Mecanica Answer on the Re: Problems with Hyundai Sonata gearbox
Czech I see that all of the bolts were, including those of the start and their cables, the pallieres sacalos is easier, release the supports and now, now if you have clutch with hydraulicotende rolling that disconnect the line that goes to the bearing and from the same and the piolas or varillage of the gear selector.
