Mazda 323 Year 2000
14 years 3 weeks before #22559 by manual-mecanica
Manual-Mecanica Response on the Re: Mazda 323 year 2000
Hello, apparently they have not scanned it, to see Q Fallas code has, on the other hand if there is no spark, the camshaft sensor is because of the camshaft sensor, if it does not inject it would be good that you check the fuel pressure as well as the filters and checks the injectors, since in some cases there are usually fuel flow but no assignment eye in the end I hope it helps you help you.
