Failure in 4runner
14 years 9 months before #16116 by manual-mecanica
Failure in 4runner published by Manual-Mecanica
Maybe someone can help me, I have a 4Runner 2000 that suddenly turns off, and the strange thing is that the P1300 Q code appears is supposedly from the lighter, so I do not know if they are related or I do not know, someone who helps me will thank you very much! : SIDE:
14 years 9 months before #16149 by manual-mecanica
Manual-Mecanica Answer on the Re: Failure in 4Runner
According to my code library, it is saying that you have a malfunction in the ignition system, not the lighter, then if you have failure in the ignition system there is no spark and the engine dies, I descendate if it is direct ignition (without distributor) or still with a distributor, also, if it is direct ignition, check a crankshaft sensor, ignition module (it is generally the Impedance of the coil, primary and secondary ... and then, connections, if it is a distributor, check a hall effect sensor, connections, coil ...
