- Thanks received: 1
06-19-2025 Hits: 618 Technology
A fineness here in Chile is charged for 15000 Chilean pesos more materials is not very expensive, now if you do not have a filter key or where to leave the burned oil then you send it has done and avoid everything, you do not say that car is to see the if the air filter is easy to change as well as the fuel.
