Problems with Chevrolet Blazer Gasoline Consumption
14 years 9 months before #16273 by manual-mecanica
Hello colleagues I have a problem with a Chevrolet Blazer is driving black smoke because of the escape I have not entered to check I would know where to start thanks and I hope quickly ...
14 years 9 months before #16277 by manual-mecanica
What year is the blazaer and its displacement? Do you have the check lit? More data to help
14 years 6 months before #17572 by manual-mecanica
The Blazer is a 95 cc 4300 model I made a scanner and I got the P1952 rest of the rest this excellent I wait prompt response thanks
14 years 6 months before #17609 by manual-mecanica
Greetings that code is from the MAP Sensor, this sensor measures the amount of air that enters into the INTAKE, and allows the mixture to be complied with according to the load that is applied to the engine, verifies if the spark plugs are flooded? Change the sensor and delete the code.
