Little power a volskwagen pole 1.9 sdi
14 years 9 months before #16284 by manual-mecanica
Little power a volskwagen pole 1.9 sdi published by manual-mecanica
He was made a change of hoops at the reason that the lid joint had blown and after this work is a decrease in the power of the engine even does not pour black smoke due to the sppa, as he strives it to the engine, since he already scan and does not give me any fault in the system if someone has an idea I thank you.
14 years 8 months before #16568 by manual-mecanica
Manual-Mecanica Answer on the Re: Little Power A VOLSKWAGEN POLO 1.9 SDI
Hello, look at it the flow if it carries, because if you fuck you, the flow takes away power, look and comment, greetings
14 years 8 months before #16612 by manual-mecanica
Hello to know better you have to install the Scaner and look at the continuous mode how the MAF sensor works since that sensor measures the amount of air aspirated by the engine and on it gives it the right amount of fuel greetings
