Toyota Hilux Motor 2Rz, not part in cold
14 years 9 months before #16321 by manual-mecanica
Toyota Hilux Motor 2RZ, not part in cold published by Manual-Mecanica
Hello friends, I tell you that I have a Toyota Hilux Year 2000 Motor 2RZ, which has cold starting problems. It was fine but when I took out the engine to repair some things between them to remove the tray and place yoke or rigid differential, it has problems in the morning. Please someone who can help me
14 years 9 months before #16328 by manual-mecanica
Manual-Mecanica Response On the Re: Toyota Hilux Motor 2Rz, not part in cold
Well Pedro looks at many more details you do not give but I can tell you that the problem of cold games usually and in 98% of cases is direct guilt of the motor temperature sensor, you can provise it with a tester to see how it is, it may be out of range and therefore it costs you is if you do not have the check on, the 2RZ engine is not a complicated engine so it is that you have to fix it.
14 years 9 months before #16381 by manual-mecanica
Hi Mr. Karma today takes her to the Industrial Lyceum to put her into the computer and see the theme of Chek Engine .. and I tell you that we check it whole and according to the computer does not throw any fault (being that this is on in the Establlero), but it continues to cost me for the game unless Bencina puts him by the multiple of admission and there is a drowned drowns of course but part. But that is not grace. I tell you the faults that the truck has .. First the game in cold, the consumption of excessive and finally when I accelerate it moderately abrupt, but once on high it works well. That is the failures in broad strokes.
14 years 9 months before #16386 by manual-mecanica
Because of the failures indicated, everything points to the temperature sensor, now if the Scaner does not yield you anything, it may not be the software for that model, in general there a little problems with the Scaner for Toyota for example for the 5E since there are few scanner who recognize it, if you want to bewitured you can or put it in a different Scaner and layers of reading this model or taking out the temperature sensor Sensor is not expensive, depending on the country where you live.
14 years 8 months before #16398 by manual-mecanica
Sorry you talk about a Truth Diesel engine :(
