harden suspension A3 1.9 TDI
14 years 8 months before #16330 by manual-mecanica
harden suspension A3 1.9 TDI published by Manual-Mecanica
hello again. Would anyone know how to improve the stability of my car, would it be advisable to change the stabilizer bar for another tougher to avoid the balancing of the corcer would? Another option would be replacing stabilizers with others? longer? I would appreciate a hand. Greetings to the forum.
14 years 8 months before #16369 by manual-mecanica
Manual-Mecanica Response on the Re: hardening suspension A3 1.9 TDI
I would exchange the docks for others tougher or those that you carry a bit for the shock absorber below again some somewhat bungling since the car also lowers the distance that cuts it ;)
14 years 8 months before #16373 by manual-mecanica
What cut the docks ??? I do not think it is a good idea friend. My intention is to improve the behavior not the aesthetics, since lowering the car with the original damping what I am going to get will be to break it in a couple of days. But thanks for the idea.
14 years 8 months before #16374 by manual-mecanica
When placing the Masssssssssss short, the shock absorber has more compression and the suspension becomes firmer. There are those who cut the docks I have told you as a point
