Moltle Light Witness in Mercedes Viano 2007
14 years 8 months before #16352 by manual-mecanica
Molten Light Witness in Mercedes Viano 2007 published by Manual-Mecanica
Hello guys, I have a Mercedes Benz Viano 2.2 116cv and suddenly I was turned on the melted light witness but the car on the outside does not have any molten light, does this happen to you? Thank you very much for your help
14 years 8 months before #16830 by manual-mecanica
Manual-Mecanica Response on the Re: Moltle Light Witness in Mercedes Viano 2007
They usually give problems the enrollment light pilots who enter water and the bulbs make bad contact.
If everything is correct look at the watts of the bulbs that are all the same.
If all this is correct, the problem could be the electronics that turn on the lights called Sam
14 years 8 months before #16851 by manual-mecanica
Thank you very much for your answer, I will try to have such thanks
