AA goes crazy ... it disconnects and connects alone.
14 years 8 months before #16365 by manual-mecanica
Hello to all the foreros.
I need, for anyone who wants to hold a hand ... some response or solution to a breakdown, which I suppose will be electric.
My car is a BMW 316i E36 of the year 1991. When I connect the
Air conditioning, it's a little crazy; It is disconnected and connected
The alone until it stops working because the fuse jumps
CORRESPONDING.
I have loaded the air and have changed the pollen filter and worked perfectly ... but it has returned again has worked as evil.
It would be very pleasant, if someone advised me or gave me any solution.
THANK YOU.
Kotufaboix.
14 years 8 months before #16368 by manual-mecanica
This smells like reluctance with fogged contacts or a party cable or that touches the dough
: P
14 years 8 months before #16457 by manual-mecanica
Hello:
I have had a similar problem in my air of my E36, but in the end, after working erratically for quite some time, I stop working definitively.
I fix it following the intruptions of this page that attached to you. www.macadamizer.com/bmwfix.html
In the end everything consisted of changing a control module capacitor. The page is in English, but there are many photos that help you encourage you to do it.
If you want and with time ahead I can help you translate the page
Greetings JBJ
