Astra 2000 clutch change
14 years 8 months before #16372 by manual-mecanica
Astra 2000 clutch change published by Manual-Mecanica
Hello everyone changed the clutch to my golf and it was bread eaten but now that I am changing to an Astra 2000 is a mess. There is not enough space to only get the box. Can we help me with your advice or suggestions? Greetings to all. Thank you
14 years 8 months before #16391 by manual-mecanica
Manual-Mecanica Response on the Rera 2000 clutch change:
Hello look I have x some Qt manuals can serve but I only need to know if it is Opel or Chevrolet; And what engine does it come out? I am facilitated more. greetings.
14 years 8 months before - 14 years 8 months before #16392 by manual-mecanica
Hello thanks for answering! The motor is 1.8 -16v Cevrolet. Download 2 manuals one that almost does not see the illustrations but the same helps. The other is excellent but one thing is to see the schemes and another is to do it. The basic problem that is presented to me is the lack of space in the engine compartment since it does not fight the box. I already separate the engine box but I am missing like 20 cm. to separate it at all and that can take it out. My fear is that I must get the whole engine!
Last edition: 14 years 8 months before by .
14 years 8 months before #16420 by manual-mecanica
: UNSURE: You have to remove the crib that under the engine and the gearbox holds the radiators removes the exhaust drop the connection of the direction the straps the lower rotulas once the crib the crib is the nuts of the transmissions and the removes cover the seals so that it does not throw oil and already releases the starter engine and the screws of the wrapper luck
14 years 8 months before #16463 by manual-mecanica
I confirm the last answer. I have made many Astra clutches of 2000 and I have always removed the subchasis.
