Xantia 2.1
14 years 8 months before #16385 by manual-mecanica
Xantia 2.1 Published by Manual-Mecanica
I have no current in the painting, multiple failure, the ctakms, ctarpm does not work, heater (the witness does not work or the heating, intermittences and fault light act either. Revised all the fuses. It coincides with the breakage of the service belt
14 years 8 months before #16390 by manual-mecanica
Manual-Mecanica Response on the topic Re: Xantia 2.1
Check the battery is the first thing you should do
14 years 8 months before #16404 by manual-mecanica
The battery is also, I have also proven the fuses of both the interior and those of the motor compartment. It has "mosqueado" a relay that goes inside the box of the command unit that made me noise when squeezing the fuse No. 5 of the motor compartment and the vehicle stopped.
