Good I am new in the forum and I had a query to make you if anyone could help me. vehicle. The refrigeration system works correctly, water circulates perfectly through the circuit. I would thank you if you could do a hand.
Hello, change thermocontact that is on top of the radiator with a similar thread like a spark plug and cables arrive, you may be heated and glued contacts and they are always connected.
