Hello, I hope to be helpful and help me, I have a PDF manual in Italian of the Daewo9o Ladies then I insert it, I have a problem with the gasoline pump of this vehicle, replace it and work well two days then I stop working I do not locate the pump relay someone will know where it is located ... I think that is the fault I will change all the fuses today ...
If you want to rule out that the relay is the problem, put a food cable to the pump from a fuse that is energized with the key is in contact, it tests it a few days and if the original installation is very czech.
