Oil in the water ..
14 years 8 months before #16419 by manual-mecanica
water in the water .. published by manual-mecanica
I am seeing a Towner Asia ... I am changing the butt joint ... Tedo ok ... but I still mix ... there someone who has the manual of this engine ,,, or tell me on an internal seal ... thank you ..
14 years 8 months before #16423 by manual-mecanica
Manual-Mecanica response on the re: oil in the water ..
Is the Towner oil? If so, look where the oil filter is going if you have a heat exchanger, it is like a ploma base in which two water hoses enter, if you have it bridges the hoses and skip the exchanger, if not, there are guinea pigs that have cells under the cams, it is unzipable but passes.
