Jetta/2000 2.0 Motor Tour problem
14 years 8 months before - 13 years 9 months before #16477 by manual-mecanica
Jetta/2000 2.0 Motor Tour problem published by Manual-Mecanica
Hello, friends of the forum ... I want to comment (and ask for advice) about a problem that I have with a VW Jetta 2000 with 2.0l engine ... It happens that the carter breaks for a blow with a stone of the road, after having changed the carter (we take three weeks to get it) You can not turn in the other position ... If anyone knows what it should, I will appreciate their kind comments and suggestions, because this problem has already been perplexed and confused ...
dear friends, I notify you that the problem was already solved, what happens is that the alternator was glued and that is why I did not turn in a direction ...
Last edition: 13 years 9 months before by . Reason: Problem solution
