My car is slowed to the front wheels.
14 years 8 months before #16669 by manual-mecanica
Manual-Mecanica response on the Re: The front wheels are slowed to my car.
Hello my friend looks at the brake fluid, cade is changed ten or twelve months for safety devotted to the high temperatures in which his tendentium is already working to apsorver the use of the environment even working in a closed sircuito, I recommend that you change it devotted to your mooring prodlema and at the time of use,
I hope helped helped
14 years 8 months before #16671 by manual-mecanica
Ok, thanks, he accuses of that I think that another problem has been created on Sunday, the brake of a tire that expellia smoke of the Caliper is pressed and I think that the seals of the cylinder and the border the gag, what do you think?
14 years 8 months before #16678 by manual-mecanica
clear that they are damaged by temperature, but you will also have to check the dough radiations, to be sure that the fat of the bearings as well as that of homocinetic is not cooked. The brake disc can be crooked
14 years 8 months before #16693 by manual-mecanica
Ok, thanks, the safest thing is that it is, but then will I change the bearings too? : blush:
14 years 8 months before #16694 by manual-mecanica
Ok, friend thanks, I will follow your advice, your opinion is very useful. : Laugh:
