Book laluz problems
14 years 8 months before #16522 by manual-mecanica
Manual-Mecanica response on the Re: problems with laluz brakes
Hello, in principle, thank you for answering I have looked at the fuses and they are fine what you do not are if the output of the mouse feed goes through the module I do not have the electrical scheme of the brake lights to see if it goes through the electronic module thank you very much
14 years 8 months before #16523 by manual-mecanica
Hello in principle, thank you for answering I have looked at the fuses and they are fine what you do not are if the output of the mouse feed goes through the module I do not have the electrical scheme of the brake lights thank you very much
14 years 8 months before #16524 by manual-mecanica
Hello in principle, thank you for answering I have looked at the fuses and they are fine what you do not are if the output of the mouse feed goes through the module thank you very much
14 years 8 months before #16591 by manual-mecanica
Then Check the Pedal Such, disconnects the connector and with a tester undeelo and proves if he closes continuity, check the easiest before putting you in the module or things like that, usually the brake lights do not go through the module that you generally mention that is why I tell you that you try the suich
14 years 8 months before #16618 by manual-mecanica
Hello the Chuit when it presses it and when it does not prescribe it does not have continuity
what I do not see clear is that when you step on the pedal ceases to have continuity and when it releases it if it has continuity
, so it is the module because it would always be fed at rest. Let us say that it goes to the other of the others when the brake pedal is at rest the chuit has continuity, when the pedal flooring ceases to have continuity (thanks for helping me)
