Vibration in braking ..
14 years 8 months before #16573 by manual-mecanica
braking vibration .. published by manual-mecanica
I work in Citroen Xantia SX, when the front train vibrates, that is, the brake plus the pedal, is it lost to pressure ??? : Woohoo:
14 years 8 months before #16587 by manual-mecanica
Manual-Mecanica response on the re: vibration in braking ..
They are probably the brake rotors (discs), which are no longer flat or better no longer have the same "grip" throughout the surface. If they still have the specified thickness, you can rectify them. But first of all verify that there are no loose/loose parts in the suspension and in the brake.
Greetings.
14 years 8 months before #16598 by manual-mecanica
It is true that vibration is for crooked discs rectify them and change the pills and now. All fixed.
