Hello, how are you like and greet everyone, I tell you that I have a Nissan Platina 2005 standard with air, the car was perfect but little by little to state presenting a failure in the mornings like 7 am (the climate is fresh) the car took it to start, at the beginning that the pump needed to give it time to send gasoline, but we In the afternoon when the heat is to everything, and it does the same, it takes a long time to start, so that they have an idea I go about 3 or 4 times from 40 to 50 sec, and then it starts without a problem and does not fail more until the next day, it does not matter if I use it only a few minutes or if I use it all day, the fault has been increasing, that is before that fault of time, but now it is almost every day. And most coincides that it is a fiddle sensor of the crankshaft or something, but I would like to know if someone has happened to someone and as they have solved it, it should be clarified that outside that the car is perfect and once it turns on it does not fail anything at all, taking advantage of a few years ago I bought an EML scan with a USB port for my laptop, will it be connected to this plate? Greetings again and thanks your help.
