Hello Miguel, a greeting and thank you very much for your answer, I only have some doubts.
1.- I really lean a lot to the postcosition sensor because it is what matches the fault the most, so I will follow the procedures that you tell me and let you know what happens.
2.- Regarding the fuel pressure regulator, if it were, the fault would be at different times, or cold and hot, etc, but on occasion I only use the car at 7 am and does not move more after that I have lit it out of the 10 at night to try to make me the failure and nothing, it simply works perfect, however the fault seems to be somewhat magical that only at night I do What you mention about the pressure regulator but how do I hope your comments.
3.- Very similar to the above if it were any fissure in some gasoline mangade, I would first have a loss that I do not notice anywhere, and surely it would notice it a bit in the consumption of gasoline, however there is nothing of that, it is its permanent strange to fail because as I mentioned only after going to sleep the car, when you wake up, the fault makes the fault and it has been increasing, it takes more and more to start. Switch that brings the clutch pedal but nothing.
Anyway, I will do what you tell me and tell you how it went, thank you for your suggestions and support and a very big hug since Queretaro Mexico.
