Mi Valiant 80 goes out to the scarver
14 years 8 months before #16720 by manual-mecanica
Mi Valiant 80 goes out to put drive published by Manual-Mecanica
Very good day friends I have a question my Valiant Voare 1980 6 Online with Torqueflit Box A-904 I go out at the time of putting drive or reverse. The rpm are couples, neither too low nor too high but anyway it goes out. From there the changes make them very soft and their time. This is already very in depression hehehe I expect your answer thanks greetings
14 years 8 months before #16725 by manual-mecanica
Manual-Mecanica Answer on the Re: My Valiant 80
It is that your problem is motor compression so you say or your box discs (it is told in Colombia) it is normally told transmission :(
14 years 8 months before #16767 by manual-mecanica
The compression relationship is not the right one may be electric and due to the spark plugs, check that they are indicated and all the same in the same way checks the spark plugs that are in good condition and the order of ignition is correct, in the motor block you can see the ignition order and guide it with the distributor.
greetings
