VW does not start
14 years 8 months before #16741 by manual-mecanica
VW does not start published by Manual-Mecanica
My vw sedan beetle is turned off the carburetor is new time is fine but Sun goes out when I stop accelerating : Blink:
14 years 8 months before #16749 by manual-mecanica
Manual-Mecanica response on the Re: VW does not start
Check the electro valve if you have current, if you check if the carburetor has enough ground contact. Check if it is fine carburated.
14 years 8 months before #16754 by manual-mecanica
If it is carburado, check the starter tend to fail
14 years 8 months before #16765 by manual-mecanica
Hey if the carburetor is new and the other boots it because it is very dirty as much as the admission camera is as dirty as the carburetor was not the electrical system at all but in the same way checks the spark plugs that have the right ones and that they are all the same but if you disassemble the insurance admission system you will find that it is covered with mud or something that does not leave the passage for gas
14 years 8 months before #16796 by manual-mecanica
In case the breakdown is electric check the accelerator sensor, since you say it goes out when it stops accelerating. Check that it is the same as the diesel. And if so, you have to give you a measurement between two connectors between 800 and 1500 ohms, and between the other two you have to give yourself infinity, as if you were cut. I hope you are lucky. Greetings
