Help, transmission oil on the radiator
14 years 8 months before #16797 by manual-mecanica
Help, transmission oil in the radiator published by Manual-Mecanica
I need help with an inconvenience, I have a charger RT with automatic transmission Touch 8, in these days I started disarming the radiator because for me that already fulfilled its time of use and I find that the transmission oil was coming out through the refrigeration tube that goes from the box for the radiator if someone could tell me to do that please.
Thank you.
14 years 8 months before #16798 by manual-mecanica
Manual-Mecanica response on the Re: Help, transmission oil in the radiator
Just change your radiator
14 years 8 months before #16800 by manual-mecanica
Hello, a great car do you have my opinion is that it is a relic that engine has?
Well to the subject, the automatic box has to be cooled its oil, the box takes oil to the radiator by pipelines to the radiator and it internally has a heat exchanger as sure that this exchanger has already fulfilled its life time and it is time to replace it now you must now check exaustively it is a state of the acite of the box since if you enter water to the hydraulic system it is very harmful and trend. speed box to try to remove the water from the luck
14 years 8 months before #16805 by manual-mecanica
Thanks for the help I was imagining just what is moisture within the transmission, I send that box to do a few months ago and I do not want to have to do that again ... The engine is a 360 my idea is to restore it completely I hope to meet my goal so I changed the radiator because it generates too much heat was thinking about buying an intercooler but I don't know that I can work so much ..
14 years 8 months before #16863 by manual-mecanica
because if you effectively you must check the transmission oil radiator because it must be with a fissure inside and because of this the oil is sneaks for the refrigeration system you must replace it and as they say in another message you must change the oil of your transmission and cleanliness of the refrigeration system ... that has helped you hehe salu2
