Problems with centralized closure
14 years 9 months before #16813 by manual-mecanica
Problems with the centralized closure published by Manual-Mecanica
Hello everyone I am new in this forum and I would like to see if someone can put a handle the problem is that I have a Citroen Berlingo 1900 d of the year 2000 and now it is that it does not close the doors the closure centered close and only opens the open doors light again is fixed on to close it I have to lower the safe of the slide door Vajo the insurance inside and closes but when removing the key from the contact, all the doors open I have looked at the fuses and there is no bad thing to do if someone can help me I would be very grateful thanks a greeting a greeting
14 years 9 months before #16839 by manual-mecanica
Manual-Mecanica Response on the Re: Problems with central locking
Hello rapata and welcome to the mechanics manuals, look at your problem is purely electric and it is not a big problem if you have Pasiensia to Checar, the closure is reopened because it recognizes that there is an aviert door and if this occurs the closure does not close to warn you that you check, even if this is not true and are all closed doors, this signal the system recognizes the open door light Aveses do not make contact there is most likely
14 years 9 months before #16841 by manual-mecanica
Hello Kikemec, thank you very much for your help but I look at that and I am pressing one by one in each puera and the light light on the problem is that now when I close the car and boy to open it the driver's door does not open with the key or inside or inside I have to be giving him several times it is worth being able to open it and when I am inside the car under the insurance of the copilot's door and they close all but as soon as the contact is closed. From the co -pilot I close it and the truth is opened again, I have thought that the problem can be at the driver's door, I don't know how to have another idea and help you what I have put a rapata greeting
14 years 9 months before #16842 by manual-mecanica
Ah he missed me thank you very much for giving me the forum ;)
14 years 9 months before #16910 by manual-mecanica
Hello, I have re -check all the doors when I tighten the pivots the open pear light in the box of the board is reduced but it is still on I have looked in case it was a fuse and neither can I make it thank you if you could give me another suggestion thanks thanks
