My car suffers from broken motor points for so many holes that in many times I can't dodge. Recently I had to remove the alarm from the short current because I went out while driving, the revolution lowered me.
When I did, it was improved, but my car every time it trembles a lot through the broken motor points and when I am in vehicular congestion, the water needle approaches the "boiling" drawing. What I do is that I turn on the air conditioning fan. My car does not have cold air as such, but I turn it down for the fan to activate and relieve heating.
My greatest concern is that while I am running, the guide is struck, the Dash is turned on, I have to light the flashing, take out my hand and make lords to avoid accident, I stop, I turn off the car and then turn it on.
Many say that gasoline is not having a good time and the injection are dirty. Well, I waited to empty the gas tank a bit, I bought a "Fuel Injection Cleaner" and I still have the problem.
What could be the problem? Is some broken manga, the broken motor points are striving the operation of the engine? Would it have to do with the electricity part?
What could be? I need your help, since I could have an accident if I guide and I have a vehicle stepping on my heels and for the moment the car goes out.
PS: I forget to indicate that my car has a full potsteering fluid, I think it is not the cause.
