consultation
14 years 8 months before #16832 by manual-mecanica
Consultation published by Manual-Mecanica
Hello friends,
I have a Toyota Corolla 1989 1.3, 2E engine, and I have certain problems I would like if you can help me, the first problem I have, is that my engine is lazy to accel change the clutch disc, the air filter and the chicler of low (104 to 115), change platinums, spark plugs and distributor cover and had no changes. These problems.
I want to check the coil and its resistance and spark plug wires that at first glance do not look bad but I do not know or if they could affect them. They would appreciate very much if they could help me thanks.
Note: The compression is in 160 and the valves are regulated AO, 20 mm and also take out the new spark plugs and look with black soot, the engine does not have blue smoke. That it can be, as I can improve
13 years 1 week before #35597 by manual-mecanica
Manual-Mecanica Response on the Re: Consultation
I hope this information serves you.
Try the fuel pump pressure.
Try the MAP sensor
check if there is no obstruction in the catalyzer
clean the injectors
