Loose car
14 years 8 months before #16833 by manual-mecanica
Lojo Auto Published by Manual-Mecanica
Consult 54 minutes ago Karma: 0
Hello friends
I have a Toyota Corolla 1989 1.3, engine 2e, and I have certain problems I would like if they can help me, the first problem I have, is that my engine is lazy to accel change the clutch disc, the air filter and the chicler of low (104 to 115), change platinums, spark plugs and distributor cover and had no changes. I would like to know how to solve these problems.
I want to check the coil and its resistance and spark plug wires that at first glance do not look bad but I do not know or if they could affect them. They would appreciate very much if they could help me thanks.
Note: The compression is in 160 and the valves are regulated AO, 20 mm and also take out the new spark plugs and look with black soot, the engine does not have blue smoke. That it can be, as I can improve
14 years 8 months before #16838 by manual-mecanica
Manual-Mecanica Answer on the Re: Auto lazy
The oyin is a bad mescla of the carburetor, not only the low uja is changed the relaxation of aujas for that engine should be 95 in low and 135 in high if the time strip could also be affecting the distributor's cam Hoooooooooooooooolales pue
