Corsa Evolution 2003 Alarm blocked
14 years 7 months before #16959 by manual-mecanica
Corsa Evolution 2003 Blocked by alarm published by Manual-Mecanica
Hello friends,
I have a Corsa Evolution 2003 1.8 cc. And the problem is that it is blocked by the alarm, according to the scanner.
for which you have to introduce a key or something.
If someone has information on the subject, I would appreciate it.
Greetings.
14 years 7 months before #16969 by manual-mecanica
Manual-Mecanica Response on the Re: Corsa Evolution 2003 alarm blocked
It is true to get the code to be able to act the vehicle, is it the same thing that happens to the Citroen, you can enter the starting code, did you disconnect the battery?
14 years 7 months before #16973 by manual-mecanica
that is, you have to pay Salfa if or yes, a dry Corsican mechanic that has some data please thank you.
14 years 7 months before #16986 by manual-mecanica
Try an electric find if the alarm unlocks and take it out, but to do there is unless you are in Santiago.
