The Nacional Voyaguer 2000 Riel is empty
14 years 8 months before #16974 by manual-mecanica
The Nacional Voyaguer 2000 Riel published by Manual-Mecanica
Can someone help me about it, thanks
14 years 8 months before - 14 years 8 months before #16978 by manual-mecanica
Manual-Mecanica Response on the Re: The Nacional Voyaguer 2000 Riel is empty
If you tell me what '' Riel '' means it may help you, never listen to it.
The model a Chrysler Voyager I guess.
Last edition: 14 years 8 months before by .
14 years 8 months before #16987 by manual-mecanica
Czech the pressure valve, aveses discharge everything in return, try strangling the retern with a caiman or pliers.
14 years 1 month before #21924 by manual-mecanica
I refer to the injectors manner, the TRANCA TRUCK until the third or fourth time I act on the switch
14 years 1 month before #22055 by manual-mecanica
Czech the injector rail prection does not reveal less than 45 psi. The fuel pump in its ineterior has a chec babble that retains the fuel borders if this happens, it is sure that it is a fuel pump but you have to carve other things as a cassado injector, a precion regulator in poor condition
