Hopefully someone can help me with this failure, what happens is that I have in the workshop a voyager 97 q when it is heated it goes out and you have to wait a few minutes to then start it only that it advances a little and it turns to turn out it already put the scanner and I mark two code one that indicates me failure in the primary/secondary circuit of the ignition coil and the other intermittent loss of the CMP or CKP. Hopefully someone can help me because I don't locate the crankshaft sensor to check it. THANK YOU
