Hello guys, in April my dad bought me a Corsa City 1.0 of the year 98 ', and I was learning to handle, so when I had been with the car for two months, I started giving problems. Derrepente was driving and the engine went out ... after a few minutes I made it walk and ran again. This began to spend more followed ... and the waiting times were increasingly long. He took him to make him a scanner, and I got out that they had disconnected the Check Engin, so every time he stopped I did not turn on any light. Now I fix that light ... and when you stop ... but it is already a problem and I don't know what to do with it. I leave my house doi a return to the roundabout and stop and I have to wait like an hour to walk just a few more blocks and stop again.
I do not understand mechanics, but it has happened to help.
These are the codes that came out in the first scanner.
- Po 650: *Active check Engine
*Light Circuit Open Open
- PO335: History (CKP Sensor CUANIAL POSITION)
RPM NON -SIGNAL SENSOR
- PO 100: HISTORY
MASS AIR FLOW VOLTAGE LOW SENSOR SENSOR VOLTAGE LOW
now I will do the second scanner and there you will see ... I hope I don't get expensive.
