I have a problem with my car, well the problem is that it does not start is an injection problem, when analyzing the subject I realize that my car has two bone pumps added an external pump, short story took the pump to try it on the outside and it worked when applying the running current, then I went to verify the circuit, I disconnect the pipe that arrives with pressure to the carburetor I realize that I arrive, then I said the injector. Have faults, I would like to know what you think friends hopefully help me to find the problem Greetings will be communicating us
