Berlingo 2.0 HDI, does not start with low temperatures
14 years 7 months before #17106 by manual-mecanica
If the incandescence spark plugs are new, the battery also and the roart engine works correctly consists of the pressure of the low circuit, it has to be approximately 3.5 bar, change the gasiol filter, and if all this does not work, it is time to check the excess of the injectors and the high pressure, it is last with a diagnostic equipment.
