Fixed airbag light problems
14 years 7 months before #17150 by manual-mecanica
Manual-Mecanica response on the Re: problems with fixed airbag light
Hahahaha, well friend what you have to do is put a computer or scaner and that erase the code usually in the French models this light lights, when the battery is changed, or for wear of one of those of the connectors that ban under the close.
14 years 7 months before #17158 by manual-mecanica
Fix the cable that hooks in the pyrotechnical belts and if you fail to fix the bridge with the ABS. With the light of ABS on if you pass itv
14 years 7 months before #17160 by manual-mecanica
In Cantabria if they throw you back if it does not make you the check, the covers of the lamp here is not worth, normally as they tell you they are usually the connections that go under the seats, a greeting.
