Nissan Micra 1.5D GX No For the Motor
14 years 7 months before #17502 by manual-mecanica
Manual-Mecanica response on the Re: Nissan Micra 1.5D GX not for the engine
Give me your engine type and chassis
14 years 7 months before #17505 by manual-mecanica
Hello.
In the documentation of the vehicle the following data appear:
Brand: Nissan
Type: K11
Variant: E02
Commercial denomination: Micra
Motor: Brand: Peugeot
Type: D-VJZ
Number Baster: Sjnecak11u3038642
These are the data that appear in the documentation, but if you need another type of info, or photos or anything else, do not hesitate to tell me.
Thanks and greetings.
14 years 7 months before #17512 by manual-mecanica
It is worth something we have. Saves what is Clausor? This clauses has a starting bombin -you have to start the engine and remove the bombin connector has to stop the engine in theory ^(Claosor is where you put your key)
14 years 6 months before #17540 by manual-mecanica
No no. The car does not stop.
I have tried to remove the battery, and the car is still underway.
I have removed the 2 connectors that go to the pump that are, one of the unemployment electrovalve, and the other that is the anti -bar.
But the engine is still running, and it is because the electrovalve does not close well, the problem is to access the electrovalve, because you have to take a lid from the pump, and wears breakage screws. It occurs to you how to remove them, to access the electrovalve?
Thank you.
14 years 6 months before #17541 by manual-mecanica
Thank you.
