reindeer Urgenteeeeeeeeeeeeeeee
14 years 7 months before #17147 by manual-mecanica
reindeer megane Urgenteeeeeeeeeeeeeeeeee published by manual-mecanica
It is revolused is only a 1.6 16 injectyon valves
14 years 7 months before #17155 by manual-mecanica
Manual-Mecanica Response on the Reno MEGANE URGENTEEEEEEEEEEEEEEEEEEEEEEEEEEE
It is stirred when you walk, in neutral, when you reach a corner, how much is 2000 rpm, did you check the IAC, false air tickets, how is the clutch? More data if it is not very complicated, I suppose your engine is a K4M like all 1.6, but we need a little more information if you light the lights down the revolution or it is the same.
14 years 7 months before #17161 by manual-mecanica
If you revolutionize and do not progress the clutch skates you
14 years 7 months before #17213 by manual-mecanica
is the butterfly box
