ROVER 200 BOARD OF CULATA
14 years 7 months before #17225 by manual-mecanica
ROVER 200 BOARD PUBLISHED BY MANUAL-MECANICA
Hello good night, I need your help, I have a 200 rover to which the Board of the Bill was burned, since I had oil in the water. Here is a great discrepancy about which Junta should put. If anyone knows which one is better please let me know thank you ...
14 years 7 months before #17228 by manual-mecanica
Manual-Mecanica Response on the Re: Rover 200 Board of Cyatics
Your rover Biene with Motor Onda right ?,
14 years 7 months before #17229 by manual-mecanica
with granted right?
14 years 7 months before #17285 by manual-mecanica
It is a 1400 16 valves, I think that the Honda has a variable distribution this is not, but nowhere says neither rover nor Honda
already thanks ...
14 years 7 months before #17286 by manual-mecanica
Hello friend, you can mount the JGO of joints of the Land Rover Freelandre that carries the same engine, it goes from fable, I have already mounted a couple of them, and without ... problems, 45000kms and about 30000 the other circulated.
Greetings
