Opel Corsa Year 94
14 years 7 months before #17379 by manual-mecanica
Opel Corsa Year 94 Published by Manual-Mecanica
Hi, I have a problem with an Opel Corsa from the year 94
when I put the heating with hot motor comes out hot air but when the air has been running for a while, despite continuing the hot engine
14 years 7 months before #17478 by manual-mecanica
Manual-Mecanica Response on the Re: Opel Corsa year 94
saturated heating radiator, saturated passing valve .... ducts or saturated pipes ... etc.
regards
14 years 7 months before #17500 by manual-mecanica
Also check your thermostat, sometimes they are removed and this causes the engine to be at its optimal working temperature, but the refrily that circulates through the heating is already a bit cold
