Hi, I have a problem with my Opel Corsa 1.7 dt. Well to the mess, my problem is that when I put a strong braking, it is heard below the gear lever as if I had taken a stone or something similar, it sounds like a quite strong clack. When I looked at it the other day I had broken the front motor support but when changing it continues to do so. I have looked at the brakes (pills and clamp and apparently are fine), the rest of the support and rotula and everything seems to be fine. Has anyone happened to anyone? I would appreciate help. Thank you so much
Hello, how are you, to see if it is going to be the ABS that you say it sounds ... if not, look to see if it is the rear motor support, that the same is leg.
Look at the general noise is the tracero motor support, it be good but moves the engine back with the hand and sees if it plays, that support is bomber to the box, the problem is that the bolt is harder than aluminum and avosina, and there is a game that is not seen with the naked eye but it is done, if that is not check the rotiles or trays, but I think that in my work problem a lot of a lot.
