Ignition problems with my R 19 of 94 1.7
14 years 7 months before #17432 by manual-mecanica
Ignition problems with my R 19 of 94 1.7 published by Manual-Mecanica
Hello, my problem is that my car sometimes was walking well and suddenly I went out, I left it for a while and then as if nothing turned on; they told me that it was the transformer of the electronic module I change it and nothing, I change the high cables, the spark plugs, the distributed and nothing, when I try to turn it on it sounds like a drown sound but not even tried to pretend to pretend you thank you
14 years 7 months before #17451 by manual-mecanica
Manual-Mecanica Response on the Re: Ignition problems with my R 19 of 94 1.7
Look if you don't have the distributor very advanced, I had a similar problem with my R 9, the distributor was very advanced and hot started but in cold it was almost impossible to turn it on.
To advance or delay it loosen the base of the base and turn it very mild, Mark it first you can put it in the same position for doubts. This I solve my ignition but what goes out walking or idea.
luck .
14 years 7 months before #17452 by manual-mecanica
It occurred to me one thing for which the car is turned off, if you have alarm with motor or engine cutting, check the cables well that while Andes move, the motor's current is short and cut, hopefully that is that. Greetings
14 years 7 months before #17486 by manual-mecanica
In general, this failure is attached by the ignition or coil or contact sheet module, they are the three things to review when you are handling and the car stops alone. to logical the pump.
14 years 7 months before #17487 by manual-mecanica
I forgot, if the ignition module is inside the Sacalo distributor lengthening the cables and putting away avesites are heated and stop working.
