Purge of the hydraulic bomb of a Chevy Monza
14 years 7 months before #17437 by manual-mecanica
Hydraulic pump purge of a monza chevy published by Manual-Mecanica
How, I have a Chevy Monza with hydraulic direction which I have not changed the liquid since I bought it, I have only filled it but it has been two or three times in 10 years.
I want to change it but I don't know if I have to purge the pump and if so, how to do it?
Thank you very much and I wait for your answer.
14 years 7 months before #17474 by manual-mecanica
Manual-Mecanica response on the re: purge of the hydraulic bomb of a Chevy Monza
Better leave it like this ... If you are not a mechanic and even if you were advised that you do not try to change the ATF (automatic transmissions fluid) if you are not careful not to contaminate the hydraulic circuit ... you will have serious problems ...
Procedure is the following ,,,
Verify leaks ...
Ubica Warrin (ES) in DIRECTOR AND VE VIDEO
Ready ... greetings ...
PS: Better leave it so even are 10 years
14 years 6 months before #17522 by manual-mecanica
Thank you very much Fran I will follow your advice. Thank you so much. I will only be checking the level.
