The VW goal radiator fan does not turn on
14 years 7 months before #17444 by manual-mecanica
Does not turn on the VW goal radiator fan posted by Manual-Mecanica
Knights, good night.
I would like to ask them what I do with my VW Go, because I do not turn on the radiator fan and because when I have to stop me because the car is reheated and I have already tried to leave the ventilator engine on and check out the fuses and nothing.
I thank you for your contributions .....
14 years 7 months before #17450 by manual-mecanica
If you already checked the fuses, test disconnect the cables that go to the temperature bulb that is on the radiator, put them in contact one with each other, if you turn on the fan you must have a problem with the temperature bulb, you change it and go. If when putting the contact cables it does not also turn on, it can also be a problem of a relay, if not any of that, they will check the fan engine because it may have broken even if it is the least likely.
Greetings, be lucky.
14 years 7 months before #17455 by manual-mecanica
Good, look first if the thermostat opens, if you do not open there you have the problem, but nevertheless, the thermostat opens, looks at the thermalvalvula, which you have the same thing, or it does not arrive current, and that is why the electro does not jump
14 years 7 months before #17469 by manual-mecanica
Knights, thank you very much for your recommendations and I hope you work for me because it worries me about way.
THANK YOU SO MUCH.
