Hello, kisia kiso because the fiat fiat bebled ke when I start the chek of the dashboard and the engine starts badly and I turn it off and I start again and part well I have it that I have as many way.
Friend that kind of failure is easier and more economical to put a team of diagnosis, so you will avoid money by changing spare parts without seeing, it could happen to you because the IAC will be stuck, or by the MAP sensor or flow flower flow of temperature, there are many things is better the scanner as advice I tell you.
